running really bad
Old Sep 19, 2008 | 05:06 PM
camaro girl's Avatar
Default running really bad
my 97 rs is runnung really bad. i had a code for cylinder 5 misfire, so i changed the plug and the wire, it still is doing the same thing. it is very shaky and kind of like hesitant on accelaration. when i am at a light stopped with my foot on the brake it moves. when i took off the plug wire it was all corroded inside. once the new wire was in it seemed fine but the next day it was doing the same thing. my engine light flashes also. does anyone know what could be wrong? thank you for your help
Old Sep 19, 2008 | 05:12 PM
02StanGT's Avatar
Default RE: running really bad
It could possibly be the coil or Ignition Control Module (ICM). You might swap the coil around and see if the misfire moves with it (looking at the codes). Although unlikely, the fuel injector could be faulty. I would try the coil first.
Old Oct 26, 2008 | 06:17 PM
it was the ignition coil. replaced that and runs fine. thanks for all your help
chevyguyjay
May 13, 2010 09:33 PM
Foxracing254
Oct 1, 2009 11:32 PM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
jake z28
Dec 1, 2008 05:36 PM
1badroc
Jan 24, 2005 02:55 PM
