running about 200 help !
Old Apr 4, 2007 | 05:04 PM
BryantD's Avatar
Default RE: running about 200 help !
Stock thermostat for that car is a 195 degree thermostat. (You can get a cooler thermostat registered at 180 degrees.), so when the coolant reaches 195 degree, the thermostat opens, but the coolant does get a little hotter than the thermostats registered temp. So, I would have to say that that temp. is normal. Easy test...replace thermostat with 180 degree thermostat and see if the temp stays around 185 - 190. If it does, then themotor is fine. If it still goes up to around 200 degrees, you have another problem. I would say a slight crack in the head gasket.
Old Apr 5, 2007 | 07:20 PM
Chappie99's Avatar
You are probably using the stock tempguages. Not always accurate.
chevyguyjay
May 13, 2010 09:33 PM
Foxracing254
Oct 1, 2009 11:32 PM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
jake z28
Dec 1, 2008 05:36 PM
1badroc
Jan 24, 2005 02:55 PM
