running about 200 help !
Old Mar 25, 2007 | 01:21 AM
Pro_built7's Avatar
Default running about 200 help !
hey guys my buddy just bought a 94 3.4l 5spd and it runs constantly at about 200-210, is this normal ? i know mine (the exact same model) runs at about 180-185 consistently, but i have a CAI and new water pump along with recent rad flush, anyway do you think something is up with his it seems to run fine though the temp stays a little high ???????
Old Mar 25, 2007 | 03:11 AM
jimidude87's Avatar
Default RE: running about 200 help !
it could possibly be a head gasket cause when mine blew it ran about that temp for a while and it seemed to run fine and then after a while of doin that it started to run bad
Old Mar 25, 2007 | 03:53 AM
badinfluenceRS's Avatar
thermostat...water pump...coolant...
You would kno if it's a head gasket by loss of coolant, white-sweet scented exhaust smoke...
Old Mar 25, 2007 | 01:46 PM
JaySan's Avatar
i thought that was the operating temp.
Old Mar 25, 2007 | 02:27 PM
blackz87's Avatar
Normal operating temperature with a stock themostat.
Old Mar 25, 2007 | 02:43 PM
Ratman's Avatar
Take the cap off and let run, maybe you just have air in the system, put a bucket under it so that you can catch the overflow and pour it back in. Same thing happened to me and I also thought it was a gasket.
Old Mar 25, 2007 | 10:34 PM
DKap22's Avatar
stock thermostat runs at 195
Old Mar 26, 2007 | 12:12 AM
stock therm lets coolant in @ 195...that's not the normal operating temp tho
Old Mar 26, 2007 | 07:56 PM
Pro_built7's Avatar
ya guys i checked the coolant, its fine, but the car is still running at about 195-210 somewhere in there, runs fine tho any suggestions ? the temp is consistent tho
Old Mar 26, 2007 | 07:58 PM
Andross's Avatar
I blew a head gasket once and it caused my car to run at 270!
Normally 160... it wasnt pretty
