Round 3? (Cyl: 6 misfire)
Old 03-31-2012, 05:20 PM
Jeez, there's not much left. How about a cracked spark plug? Any chance it could have gotten damaged when you replaced them. It can happen, especially where access is a pita.
Old 03-31-2012, 07:02 PM
PiN's Avatar
PiN
PiN is offline
Pete, that is a good suggestion, I will attempt that next. Spark plugs are okay.
Possible bad computer or off chance an o2 sensor like off the catalytic converter effecting it?
I don't even want to really think computer for a 1995 3.8 liter. Aren't the only ones that will work on them are the 95's since they changed the engine the year after?
Old 03-31-2012, 07:54 PM
Since an 02 sensor monitors a bank of cylinders (in your case 3), it wouldn't be able to trip a specific cylinder code. That would be random misfire.
Old 04-02-2012, 01:08 PM
microkid's Avatar
March 2011 ROTM
Technical User
sounds like dr's scenario, but hers was only after a long drive it set a code for cylinder 6 misfire. the head was cracked between the valves, and the 3800 is very prone to cracking any time its overheated more than once. she still had good compression and passed a cylinder leak down test when cold, was only once it was hot the crack would open up
Old 04-03-2012, 01:19 AM
PiN's Avatar
PiN
PiN is offline
Checked old ICM and it read okay but the guy seems very not sure so I bought a new ICM installed via Pete's suggestion with no differences. I guess I'll drive it around for a couple days in its ****ty condition and see if I can get the computer to spit out some new codes.
Could the computer be bad?
Also Mirco I pressure tested again while hot. Still read okay. Still getting right fuel mixture...I am truly stumped at this point.
Old 04-05-2012, 09:48 PM
PiN's Avatar
PiN
PiN is offline
Still working on it. Mirco, do you have a link to Dr's discussion? I'd love to read threw it.
Old 05-14-2012, 04:04 PM
PiN's Avatar
PiN
PiN is offline
So I thought I'd give an update and a thanks to all that helped me. I FINALLY found the problem. I bought an flow chart of all the sensors and traced it back to the catalytic converter and sensor and will be installing them tomorrow.
I figured I would post this for future reference in case someone runs across the similar problem.
Thanks again.
Darko
West
11-27-2012 03:11 PM
Camarokid94
11-13-2012 08:50 PM
camaro5ryan
10-13-2010 11:14 AM
Jr. Mechanic
05-11-2010 09:16 PM
Quick Reply: Round 3? (Cyl: 6 misfire)
