Rocker question
Rocker question
has anyone had any problems when having a 1.7 , 1.8 or 1.9 ratio rockers for their 3.8 ???
i dont know where to find specs on my camaro to check the piston valve ratios and i was just wondering if it would have problems if i used higher then a 1.6
thanks
thanks
RE: Rocker question
Changing the rocker is changing the lift and basicly like changing the cam. You can anly improve so much with stock intake and heads. You also have to look for if you have rail guided rockers and will the higher ratio rockers clear your valve springs.
RE: Rocker question
no im not gettin a cam
but ya thats what i was worried about is if i buy to high of a ratio then ill have trouble with my valve springs being off timeing
i would think that going from a 1.6 rocker to a 1.9 rocker would be too much on the cam and throw the piston tovalve off
true? or will i be ok with 1.9 rockers?
