rocker arm question
Old Apr 11, 2012 | 01:11 PM
thebandit110's Avatar
Default rocker arm question
So im putting together the gm 290 HP crate motor I purchased. I want to run roller rockers. How ever the studs are pressed in studs. Not really a fan of those. Is there a way to tap out the studs and use threaded studs?? never really had to do this before. any info on this would be really helpful. THanks - Jon
Old Apr 11, 2012 | 01:40 PM
If you don't have machine shop skills, or equipment, you'd be best off having a shop do the job:
::: MaxChevy ::: Quick and easy small-block rocker stud upgrades - 12/17/07
Old Apr 11, 2012 | 04:08 PM
well what does it require? just a tap and a bottoming tap??? and if the holes go through the water jack you do not even really need a bottoming tap... my real question (which I should have specified) is that how do you get the pressed studs out???
Old Apr 11, 2012 | 04:09 PM
oops did not see the link... thanks!
Old Apr 11, 2012 | 10:42 PM
Camaro69... Do you think I would be able to do it with the motor in the car with out taking the valve springs off???
1974z28
Aug 6, 2012 12:21 AM
78 on my plate
May 4, 2012 11:50 AM
irocktheIROC
Nov 4, 2008 07:01 PM
DKap22
Mar 7, 2007 04:45 PM
