rocker arm bolts?
Old Nov 21, 2012 | 04:28 PM
|m()d's Avatar
Default rocker arm bolts?
so can i use shcs in 5/16 18 2 inch for rocker arm bolts? They are grade 8. they look indentical to the ones comp sells. i found them at true value only diff between the tty and these is they dont have the thread less bottom tip does that matter? and should i stay with torque spec from book or give them a few extra lbs? If it matters Im bolting on series 3 heads from a 08 grand prix
Old Nov 22, 2012 | 05:48 AM
fbodyrs96's Avatar
Just get reusable bolts form zzp or intense racing, there cheaper than the tty and there 22-23 ft lbs.
A1SlowHand
Sep 28, 2012 04:38 PM
carkivey3
Dec 6, 2009 11:44 AM
awake1630
Apr 2, 2008 11:04 AM
pyrofire127
Mar 17, 2008 01:48 PM
thebandit110
May 4, 2007 08:01 PM
