Replacing Bolt from bellhousing
Old Jul 23, 2009 | 12:11 AM
RFxCamaro's Avatar
Default Replacing Bolt from bellhousing
Where can i find a replacement bolt for my 96 v6 5speed bellhousing. As it is there are two missing from the bottom and there is a nice gap. Also what kind of problems would this cause? Ive noticed that no matter how hard i try i can never seem to get into second gear right, it always jumps as if i was barely starting to learn manual.
Old Jul 23, 2009 | 12:13 AM
RFxCamaro's Avatar
Old Jul 23, 2009 | 12:32 AM
check at your local chevy dealership. they still have a few parts for the lt s, ya never know. and they should be able to tell u what it is. my book for 93 shows a cover screw m6.3x1.81x20
Old Jul 23, 2009 | 12:41 AM
those screws are for the cover and would not effect shifting. you could have a trany mount going but from what is in the pic i would say u got some oil on the clutch and that will make it grab. also will go to pieces if thats whats going on. change the intake manifold gaskets if u havent, make sure to clean the front and back block and intake surfaces extra well. the rvt seal is known for falure on those two surfaces. then get under there and clean that up. lol
Old Jul 23, 2009 | 01:02 AM
RFxCamaro's Avatar
how do i test the intake manifold gasket? i had a mechanic tell me that the lower gasket was causing a vacuum leak but when he took it apart we found out that it was fine and it was something else causing a coolant leak. by the way its not a an lt1 its a 3.8, nd yes there is oil but im not a master mechanic and tought it was leaking because it was loose, i thought there was suppose to be fluid in there
Old Jul 23, 2009 | 01:32 AM
oh, gettin tired. sorry my bad. the screw should be the same size for the rs. hardware store should have one. sure looks like the oil is coming from up above the trans but could be its blown back. nope dont want oil in there. are u losing clutch fluid?
Old Jul 23, 2009 | 01:35 AM
RFxCamaro's Avatar
how can i tell if im loosing clutch fluid
Old Jul 23, 2009 | 07:52 AM
check the fluid in the clutch cylinder reservoir, should be under the hood by the brake cylinder reservoir.
camaroteen82
Dec 21, 2013 11:04 AM
redrumrevolution1
Feb 18, 2010 08:26 PM
r6rider
Oct 16, 2009 01:57 AM
95ZDropTop
Apr 18, 2008 09:51 PM
