removing bellhousing bolt
Old Feb 18, 2010 | 09:24 AM
redrumrevolution1's Avatar
Default removing bellhousing bolt
I have 96 camaro 3.8. Im removing my engine and i can not get the last bolt off the bellhousing. It is the bolt at the top of the transmission on the driver side. I remove the itake system and still i cant remove. I got a wrinch on the bolt perfect but its too tight. I even put a hammer to it. PLEASE HELP!!!!!
Old Feb 18, 2010 | 09:36 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
can you get it from underneath the car with a swivel maybe? or maybe try to slip a pipe over the wrench for more leverage?
Old Feb 18, 2010 | 10:13 AM
There is no room to put the pipe over the wrinch. Should I jack up the transmission or it dosnt matter
Old Feb 18, 2010 | 08:03 PM
1998camarossclone's Avatar
jacking the transmission up will tilt the upper bolt to your favor
Old Feb 18, 2010 | 08:11 PM
osduck5's Avatar
I had to lower the tranny support so the tranny and motor tilted down and then had to get to it with an extention from the bottom. Couldn't get enough leverage on the wrench from the top with the limited space.
Old Feb 18, 2010 | 08:13 PM
CraZ28's Avatar
Banned
I had to cut a piece of pipe. Just a short piece so you can slip it over the end of the wrench and get a handle and a little more leverage. It is not torqued to tight. Keep at it......
Old Feb 18, 2010 | 08:26 PM
osduck5's Avatar
Good idea. Why do I never think of these things!
mike6208
Mar 5, 2012 06:59 AM
RFxCamaro
Jul 23, 2009 07:52 AM
lostcoz
Jan 27, 2009 04:30 PM
95ZDropTop
Apr 18, 2008 09:51 PM
