Rear end swap
Old May 30, 2010 | 09:54 AM
Jimi Dangerously's Avatar
Exclamation Rear end swap
I recently swapped out the read end of my Camaro. I own a 96 RS(3800) model. The rear end that I swapped with was the end from an 87-88 I-ROC Z28. The old Zs' rear end is slightly too narrow, and the wheels now hit the inside of the body. Is this because of the drum to disc conversion or is the rear end just too narrow. What can I do to remedy this with keeping the older rear end in? I just want to be able to keep the disc breaks and the beefier 3.23 gear in the back. Anybody have any ideas?
Old May 30, 2010 | 12:00 PM
You just need some wheel spacers. This should be the same wheel spacer you have to buy if you want to put 4th gen wheels on a 3rd gen. I think they are on ebay. Also wheels from the 3rd gen might work.
Old May 30, 2010 | 12:02 PM
BasicConcepts's Avatar
Technical User
^^ i agree wheel spacers lust get some longer studs
20camaro02
Jan 19, 2013 10:42 PM
draggo144
Mar 31, 2010 09:14 AM
dejz28
Mar 13, 2009 12:58 PM
mike83camaroBA
82-92 V8 Tech
Oct 30, 2008 12:00 AM
68ssap
Oct 8, 2007 11:04 PM
