Radio static
Old Jun 3, 2007 | 05:57 PM
ryanh_3's Avatar
Default Radio static
I have searched and searched but had no luck. When I turn my headlights on my stereo gets really static and can't find radio stations at all it also happens when I roll down the windows just not as bad. I’m pretty sure it has something to do with the alternator. Anyone else had this problem?
Old Jun 3, 2007 | 08:28 PM
bluovlh8er's Avatar
Default RE: Radio static
when my cell rings my radio turns off and on...
Old Jun 3, 2007 | 08:41 PM
ryanh_3's Avatar
Wow that’s insane. With mine if I’m listening to a cd it doesn't affect it at all its just something interfering with the radio stations.
Old Jun 5, 2007 | 03:21 PM
01 Camaro Cp's Avatar
Sounds like you're experiencing a voltage drop. You can try cleaning all your connections, battery, ground, battey to chassis and your radio ground. Also the aluminium on these ATC fuses will sometimes crode a bit so pull your radio fuse and check the blades.
The surest way to cure it is to run a seperate fusedfeed from the battery to the radio. Use a relay connected to your switch to make sure you don't drain the battery accidently. An 18awg stranded will carry about 16 amps. I used 12 awg stranded on my set up (20+ amps)
Old Jun 5, 2007 | 04:09 PM
ryanh_3's Avatar
Ok i'll look into the connections and the fuses.
libertyforall1776
Jun 11, 2015 09:09 PM
SamSpade
Mar 4, 2011 06:11 PM
c4maro
Jan 21, 2011 05:10 PM
prevarications
Feb 4, 2008 10:14 PM
