radiator hose hot and puffy
Old Nov 16, 2006 | 07:15 PM
camarorz28's Avatar
Default radiator hose hot and puffy
Hey guys i have a 94 v6'r and i have a little problem, well to me it seems like a problem. The radiator hose, the one that connects to the housing of the thermostat. Well that hose getts really hot and and it gets puffy, like if its going to blow up any minute, it gets like thise just right were the clamp connects to the thermostat housing. Any idea what can be causing this problem.
Old Nov 16, 2006 | 07:44 PM
94Z28SHAKER's Avatar
Default RE: radiator hose hot and puffy
sounds like you need a thermostat, it may not be opening properly and building pressure in that tube.
Old Nov 16, 2006 | 09:29 PM
Would be a good idea to change out the hose before it lets go. Good hoses do not swell up.
Old Nov 16, 2006 | 10:32 PM
shnormo's Avatar
Antifreeze in there too long will eat away at the hose from the inside out. While it's off, you might as well check the thermostat.
Old Nov 16, 2006 | 10:43 PM
uncle bill's Avatar
You better change it quick.
Old Nov 16, 2006 | 11:12 PM
MadMikeZ28's Avatar
Is your radiator cap working? Does the level of coolant change in the resivour and does it get warm? It may be stuck and pressure is building up in the system.
Old Nov 16, 2006 | 11:18 PM
camarorz28's Avatar
no antifreeze i told my dad too put some how much do i put in?? I'll do it for him since he will no. and i'll replace the hose, if it was the thermostat would'nt the car overheat? if so the car is not overheating temp. is cool below half mark.
Old Nov 16, 2006 | 11:28 PM
MadMikeZ28's Avatar
50/50 mix water and coolant. Check the capacity of your system and use half for the amount of coolant. Your cap might be stuck. Your hoses may be rotted also. Are they soft when they are cool? It does not hurt to change the cap. t-stat, and hoses and they should not be that expensive at an Autozone.
Old Nov 17, 2006 | 12:11 AM
camarorz28's Avatar
yeah they it is soft when cold, well thanks for the advice guys fast reply
MartineZ28
Apr 28, 2012 09:08 AM
sobelizard7@sbcglobal.net
LS Series Tech
Jul 23, 2011 07:05 AM
mab6680
Dec 23, 2010 08:01 PM
_Pirate_
Jul 27, 2009 11:57 PM
