RADIATOR FANS
Old Dec 21, 2008 | 12:19 PM
greyscot35's Avatar
Default RADIATOR FANS
2001 RS 3.8V6 Ater I start the car the fans come on and do not stop until I cut it off.
What could cause this? could it be a bad tep sending unit or what?any and all help will be greatly appreciated!!
Old Dec 21, 2008 | 02:17 PM
02StanGT's Avatar
Default RE: RADIATOR FANS
Is the defrost or A/C on when this happens? What does the temp gauge show?
Old Dec 21, 2008 | 03:28 PM
greyscot35's Avatar
No the A/C or defrost is not on and the temp gauge is at cold.it does not matter when I start the car even after sitting overnight as soon as I start the car the fans start running.
Old Dec 21, 2008 | 03:33 PM
02StanGT's Avatar
How about the temp gauge, does it always sit low? Only reason I ask, is there is one temp sending unit.
Old Dec 21, 2008 | 03:37 PM
greyscot35's Avatar
The temp gauge stay's under 100 it used to go up around 200.
Old Dec 21, 2008 | 04:19 PM
cbr600rx7's Avatar
So this is a new issue that just started not something that has been going on since you have had the car.
Old Dec 21, 2008 | 05:24 PM
greyscot35's Avatar
Yes it's a new issue,in fact it is only the second issue I've had with the car.
Old Dec 21, 2008 | 05:42 PM
02StanGT's Avatar
You might try the temp sending unit. That or a relay is at fault. But if both your fans and temp gauge are not working, I would suspect the temp sending unit as you had stated. If you are unsure of where it is, it's location is under the "neck" of the intake manifold.
Old Dec 21, 2008 | 06:27 PM
greyscot35's Avatar
Yeah,That's what I was thinking so I changed it about an hour ago and when I started the car the fans did not run,but I forgot to put thread tape on so I took it out put the tape on hooked it back up and the fan started running again.so I think I either have some tape touching the sensor or there is a short in the wire I have to let it cool back down to se whats up.thanks for all the help.
nikogto
Jun 7, 2014 03:04 PM
TNDawg123
Sep 23, 2011 03:44 PM
MTRIMBOLI
Jul 23, 2010 06:36 PM
lil spoon
82-92 V8 Tech
May 3, 2009 10:24 PM
got3ofem
Feb 28, 2008 11:52 AM
