LT1/LT4 Tech 1993-1997
fans won't come on. Tried everything I know.
Old Sep 19, 2011 | 10:05 AM
TNDawg123's Avatar
Default fans won't come on. Tried everything I know.
1995 Camaro z28.
I replaced Coolant Temp Sensor below water pump
Check both fans and they are working
Checked all three relays and they are working
Checked all the fuses they are fine
Made sure coolant level was full
Fans will not come on even when AC is turned on.
They will turn on if I unplug from Coolant Temp Sensor.
I checked the power to the relays and I have power on the #5 socket when the key is turned on, but no power on the #1 socket when the key is off.
What now?
Thank you in advance for your help.
Old Sep 19, 2011 | 12:55 PM
torque_is_good's Avatar
shoe is always a great place to start
4th Gen LT1 F-body Tech Articles
Old Sep 22, 2011 | 09:33 AM
sm515's Avatar
any chance ur new to the car and dont realize the fans dont kick in till it almost redlines? i raised this question before when i first got my 93 z, troubleshot it for a weekend then someone showed me shoebox. the entire time i simply didnt let it get hot enough. since then i wired a switch. im sure this isnt ur problem but i thought id throw it out there.
Old Sep 22, 2011 | 09:38 AM
nope, they don't kick on when A/C is selected and they should. The fans do however work as is evident when he forces a CEL and they turn on
Old Sep 22, 2011 | 08:31 PM
Psycho's Avatar
A fellow on another forum had the same problem. He either just unplugged the ECM fuse or disconnected the battery and the computer reset. The fans worked fine afterwards.
Old Sep 22, 2011 | 08:40 PM
buck658's Avatar
i would just wire a switch in, there is one online somewhere that you can buy that is designed for this. alot of people prefer to have control over their fans anyways
Old Sep 23, 2011 | 08:27 AM
TNDawg123's Avatar
I have unplugged the battery in an attempt to reset the computer (ecm), but that had no affect. I would install a switch, but when the fans are unplugged from the temp control sensor the "service engine soon" light comes on. This will keep the car from passing emmissions. As for the car needing to redline before the fans come on, surely that is not accurate? The redline on the temp sensor in the car is 260 degrees. How long before I have to rebuild the motor with those temps? I did try to code the car with the service engine soon light on, but the computer could not "communitcate" with the vehicle. Yes, the unit I used said it worked on OBD 1&2 computers. Innova 3120 is what i used.
Old Sep 23, 2011 | 08:54 AM
i have a 3140 and it wont scan a 95 either. i think you need to set it up to scann with the obd1 cable and then use this http://shbox.com/1/xraycable.jpg
test the temp sensors http://shbox.com/1/4th_gen_tech2.html#ect
Old Sep 23, 2011 | 03:44 PM
je$$up97's Avatar
either get a programmer or custom tune to lower the "on" setting for the fans. I have my custom tune for 160degree thermostat and the fans come on at the same temp. My car never runs much hotter than 170.
jimmyrayleyjr
Mar 24, 2013 03:52 PM
MTRIMBOLI
Jul 23, 2010 06:36 PM
lil spoon
Mar 28, 2009 01:10 PM
