Electric radiator fans, what works best?
Old Apr 30, 2014 | 11:53 AM
nikogto's Avatar
Default Electric radiator fans, what works best?
Anyone used a dual fan set-up from a 4th gen? I need to keep my temps down on my blown big block. This is all I have right now, it's also overdriven 20%, gonna swap pulleys and make it underdriven to hopefully lower temps also. I got the car pretty much the way it is powertrain wise, but I need to make it more streetable when cruising and sitting in traffic. Temps will climb 220+ after driving 20 minutes without traffic.
Old May 1, 2014 | 08:33 AM
Haven't used dual fans from a 4th gen, but air flow is very important, as is the coverage. The largest radiator you can fit in there, plus as much surface fan area as possible. A smaller single fan on a big radiator wont cool as well as duals with a shroud that fits the radiator. Also a puller fan setup cools much better than a pusher if you have room to have it in a puller location.
Old May 2, 2014 | 07:31 AM
nikogto's Avatar
I'm gonna move this fan over and add another fan that has it's own shroud (pt cruiser assy). This fan I have is set up on puller side. This thing will run hot while cruising, I don't sit in much traffic when I can help it. Gonna send radiator out today and get it flow tested and boiled out, add the other fan and see what happens.
Old May 2, 2014 | 09:11 AM
I assume if you're adding the other fan and a shroud, your shroud will cover the whole radiator and the two fans? It wouldn't help much if a 2nd fan was added with it's own shroud. Looks like a pretty new radiator, and can't imagine it wouldn't be clean and have good flow, but you might consider a double or triple pass radiator. They're pretty reasonable now, and often cheaper than having a radiator cleaned and checked. I just purchased a fully welded aluminum triple pass 19"x31" for my BBC powered '63 Falcon and it was $234 shipped to me.
Old May 2, 2014 | 02:00 PM
nikogto's Avatar
Not gonna send it out to rad shop. Found out by looking at this not so cheap Be Cool radiator, you can barely see any light through the fins, not just one spot but the whole radiator. I'll try to add some pics. When I look at the spare radiator on the shop floor for a S10 blazer, you can see your hand on the other side. That's definitely gonna keep air from properly flowing through and cooling the cores. I think I might pick up just a plain rad from advance today and install it to see the results with 2 fans installed. Does anyone else here run a Be Cool rad on their ride?
Old May 3, 2014 | 09:58 AM
So it's built with flow restrictions in the fins? Sounds like it must be a Be Cool thing, and might be the same with every radiator they make?
I had to go look at my radiators to see what they look like. I have two Griffins and the latest Northern. All seem to be pretty open on the cooling fins, and I can see my hand on the back side with overhead lights on.
Old May 3, 2014 | 11:38 AM
nikogto's Avatar
I've never really seen that before, why have restrictions on airflow?? Picked up an oem cheap rad from advance last night, you can see your hand through it without light. Gonna install that today and make a bracket to mount the fan in front of the radiator, new coolant and some redline water wetter and see how she does.
Old May 30, 2014 | 12:51 PM
camaros4evr's Avatar
We run a Be cool rad in our camaro, its a BB but not blown but we do race it alot, we had problems with keeping it cool also. We put a Flexalite syclone (curved blade) fan on it and it really keeps the temps down, you need something that flows at least 2500 cfm. Also a bottle or two of water wetter helps too.
Old Jun 7, 2014 | 03:04 PM
NorCal_71's Avatar
You might look into running a Taurus 2 speed electric fan, it is one of the most popular electric fans that get used for conversions. I am converting mine now because my generic electric fan doesn't pull enough air through the radiator.
Here is a site with some great info about the Taurus fan conversion:
electric fan FAQ links | IH8MUD Forum
And:
http://www.nastyz28.com/forum/showthread.php?t=200028
camaroman67401
May 24, 2009 09:10 PM
got3ofem
Feb 28, 2008 11:52 AM
1fastVelle
Feb 2, 2008 01:48 AM
jbassiii
Jan 25, 2008 06:48 PM
tmroesle
Feb 19, 2007 02:36 AM
