Questions
Old 07-08-2012, 08:23 AM
S. Toth's Avatar
This right after I gave it a bath last week
Old 07-08-2012, 09:55 AM
If you washed the engine compartment, there is a good chance that water got into a connector or or dried up wire, and causing shorts of some type. Hopefully, you didn't wash the ignition switch or underneath the dash.
Old 07-08-2012, 11:28 AM
S. Toth's Avatar
No I did not wash the engine compartment and I had the floors shampooed and cleaned all the surfaces with armorall but that's about it. I have noticed the chip in my main key was loose so I tried my spare but it is still on. Possibly in the ignition switch itself?
Old 07-08-2012, 01:48 PM
Could be the VATS contacts in the switch, key, wiring between switch and VATS module. May want to reseat the plug on the VATS module, in case it got shampooed.
Old 07-12-2012, 10:47 AM
S. Toth's Avatar
Many Thanks Ill look into that those possible fixes!
Warpig
04-20-2009 09:33 PM
bigjsmashman
02-21-2008 11:05 PM
nj93zkid
02-24-2007 01:20 PM
dubbs95
10-21-2006 01:29 PM
Quick Reply: Questions
