Question about a V6 3.8 engine replacement
Old Jul 30, 2007 | 08:43 AM
VTownSuzieQ's Avatar
Default Question about a V6 3.8 engine replacement
I have a 96 Camaro V6, 3.8, 5 speed that I picked up for free because it has a rod knock, and is need of an engine replacement. I found a motor on Craigslist for $100, but I am still learning about cars, so I'm hoping someone can tell me if the engine I found will work in my car. Here is what the posting says.
I have a 3.8 chevrolet engine. This was originally from an early 80's Camaro when the base models were V6. I had this in a Jaguar MK 2. This has an aftermarket cam. This is essentialy a long block with a water pump. Has around 30K mile from the rebuild. Needs new valve cover gaskets. Strong compct hot rod engine. Comes with factory 2 barrel rochester carb, aircleaner assembly and factory aluminum manifold, chrome valve covers, chrome alternator mount and bracket and a flex plate for turbo 400. No distributor. I have an engine hoist for loading.
Any help or advice would be much appreciated. Thanks!!!
Suzie. [sm=hail.gif]
Old Jul 30, 2007 | 12:22 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
Default RE: Question about a V6 3.8 engine replacement
triple poast wow
Old Jul 30, 2007 | 12:33 PM
genvoodoo's Avatar
And under two different names as well!!
98v6ttop
Oct 2, 2013 06:31 PM
DavidJ1907
Aug 8, 2010 09:25 AM
mmacioce
82-92 V8 Tech
Jun 29, 2009 08:08 AM
VTownSuzieQ
Jul 30, 2007 08:44 AM
coolcat
Apr 13, 2006 03:17 PM
