Pulling Codes on a 95 3.4
Old Oct 7, 2007 | 10:24 AM
cbrenn71's Avatar
Default Pulling Codes on a 95 3.4
I'm assuming 95 was a transition year for the OBD systems in these cars? The car has an OBD-II port, but the scanners cannot get anything but an error code.
Is there such thing as an OBD 1.5?
If so, who, besides the dealer can pull and diagnose? I know auto zone and advance auto do not have the capability.
thanks in advance.
Old Oct 7, 2007 | 10:27 AM
Default RE: Pulling Codes on a 95 3.4
The computer is OBDI, but the connector is OBDII. You need a OBDI scanner and an adapter cable. Most good repair shops should know about it, and be able to scan the computer.
Old Oct 7, 2007 | 10:49 AM
bluovlh8er's Avatar
i acctually have one. its like what pete said. obd1 computer but an adapter cable that converts obd1 to obd2.if u live close by cleveland ill scan it for you lol
Old Oct 7, 2007 | 10:53 AM
cbrenn71's Avatar
i actually live in lima. close, but not too close. lol
i wonder if i can pick up a cheap OBD-I scanner with an adapter anywhere?
I seem to have a "soft" code, that throws itself after about a 2 hour drive, and then it only stays on for about 10 seconds, oronce the car is shut off and restarted, it will have disappeared. I'd like to check and see if it's being stored at all, and if so, what the cause is.
Old Oct 7, 2007 | 11:07 AM
Here is how you can make one up, cheap & dirty.
http://shbox.com/1/xraycable.jpg
Old Oct 7, 2007 | 01:50 PM
cbrenn71's Avatar
ORIGINAL: z28pete
what exactely am i looking at there? looks like the OBD-1 is just pulling codes from the two pins that are jumpered to the OBD-II style connector?
Old Oct 7, 2007 | 08:11 PM
You got it.
dkn920
Nov 5, 2012 07:12 PM
Gorn
Jul 22, 2011 04:55 PM
tipdrip215
Feb 1, 2010 04:04 PM
Billdo38
Oct 17, 2007 06:58 PM
