PLEASE HELP!! What is this thing called?
Old Jul 23, 2010 | 04:11 PM
BoricuaHec02's Avatar
Default PLEASE HELP!! What is this thing called?
I'm trying to figure out what is the name of the piece in the back of the Maro where it says Camaro, some camaros have that whole piece painted black or is it a piece I can put on myself? Here is a link of a Camaro with it on, back of the car.
http://www.autotrader.com/fyc/vdp.js...standard=false
Old Jul 23, 2010 | 04:27 PM
its called a rearend finish panel and you should be able to take it off fairly easily. four plastic nuts on the inside and it should come right off. at least thats what im showing.
Old Jul 23, 2010 | 04:31 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Its called a Tail Panel. and once the tail lights are removed its 4 nuts.
Old Jul 23, 2010 | 04:47 PM
So you guys think it's an easy job?
Old Jul 23, 2010 | 04:52 PM
well pull it off and see. under the rear cover on the backside of the trail lights should be plastic nuts holding em in, also some wiring harness plugs to take out. then should be 4 more holding the panel to take off then it should come off. can you paint? im sure a paint shop would do it cheap if you bring em the part.
Old Jul 23, 2010 | 04:58 PM
That sounds nuts, I'll prolly ruin my whip. I was thinking of just repainting the whole entire car and paint that part seperate.
v64thgen
Mar 17, 2015 10:07 PM
Dana
Mar 15, 2013 10:32 AM
nickplee
Mar 5, 2010 02:09 PM
350rs
Aug 23, 2007 01:04 AM
01camaro.dude09
Jun 15, 2007 10:51 PM
