PLEASE HELP!!! 3.4 to 3.8 motor swap
Old Jun 10, 2010 | 02:05 PM
skooch20's Avatar
Default PLEASE HELP!!! 3.4 to 3.8 motor swap
i have a 95 and 96 camaro i took the 3.8 out of the 95 and put in the 96 changed all the wiring and subframes but now the motor and tranny are cockeyed on the subframe and cant put the crossmember in for the tranny
wat could be wrong???
Old Jun 10, 2010 | 02:51 PM
TorqueWrench's Avatar
Did you swap Kmembers? The 3.8 uses a different kmember than the 3.4. I cant help much more than that. We need to know what all you swapped over besides just the engine and wiring.
Old Jun 10, 2010 | 03:09 PM
skooch20's Avatar
i changed the subframe put the 3.4 transmission on the 3.8 bc they were the same and now it shifts the transmisson towards the passenger side to where i cant put the crossmember on with out getting it to move towards the driver side
Old Jun 10, 2010 | 04:39 PM
libertyforall1776's Avatar
Pictures please. ;-)
Old Jun 10, 2010 | 04:47 PM
tripwire1124's Avatar
so your doing a 3.8 to 3.8 change?
+1 on this. use the 3.8s k-member.
Why wouldnt you use the 3.8s tranny?
Old Jun 10, 2010 | 04:50 PM
95 cars were predominantly 3.4's there were a few 95 cars with 3.8's but they were rare. They were only produced for california due to emissions.
I didnt think you could use the 3.4 trans with the 3.8. Someone else chime in, but Im pretty sure they arent compatible. Also, double check the trans crossmembers, they may be different also. To swap these motors you have to use the 3.8 engine, trans, 3.8 kmember and 3.8 motormounts.
Old Jun 10, 2010 | 05:03 PM
i too dont think you could use a 3.4 tranny on a 3.8. otherwse i wouldnt have ever done the auto to manual swap.
Old Jun 11, 2010 | 02:43 PM
3.4 has the same bolt pattern as the old 2.8. It is not the same as the 3.8 bolt pattern. About 5% of the V6's sold in 95 are 3.8's I have seen 3 come thru the auction here in PA in the last 12 months.
We have some conflicting info. If its a 3.8 it should be a boltin no problem if its a 3.4 it should not bolt up so i have no idea whats goin on.
When you say all the wiring out of the 95 I hope you mean everything. Your 95 PCM is not compatible with all your 96 sub systems because of the OBDII requirment that began for 96 model year.
Old Jun 17, 2010 | 05:12 PM
skooch20's Avatar
well i got the car done and you have to use the 3.8 subframe and wiring harness out the dash but you can use the 3.4 tranny bc it bolts up to the 3.8 with no problem bc its usually the same transmission and i even used the 3.4 tranny crossmember
Old Jun 17, 2010 | 07:49 PM
Was this a tranny with a removeable bell housing?
riverman95-99
Feb 12, 2012 01:59 PM
sandvipr
Apr 25, 2011 12:03 PM
mregulater
82-92 V8 Tech
Mar 10, 2009 11:47 AM
dmolaver15
82-92 V8 Tech
Dec 20, 2008 08:46 PM
Camroman250
Apr 30, 2006 12:17 PM
