Pacesetter y pipe preventing oil drain plug from being fully removed
Old Aug 25, 2023 | 01:44 PM
ebuds's Avatar
Default Pacesetter y pipe preventing oil drain plug from being fully removed
I've recently purchased and rebuilt this 2000 Camaro 3.8l that came with pacesetter headers and magnaflow exhaust. I got the exhaust on yesterday and went to do an oil change and the damn ypipe blocks the oil drain plug from being removed. The plug hardly comes out halfway before contacting the exhaust. Has anyone dealt with this?
When I installed the exhaust to the manifold I couldn't find what gasket was supposed to be used, the stock gasket didn't fit, so I used rtv.
Old Aug 26, 2023 | 11:38 PM
have you tried loosening the bolts on the y pipe and seen if you can shift it around enough to allow bolt to clear?
Old Aug 27, 2023 | 01:47 PM
ebuds's Avatar
I have, because of how it is angled every time I tighten it, it just brings it closer to the bolt. If I unbolt the driver side, the gap is just barely large enough to remove the bolt. Its possible I'm lacking the gasket necessary, that may provide a large enough gap to remove the bolt, but the OEM gaskets I purchased didn't seem compatible with these headers, the gasket refused to center. I've since thrown them out, 🤦
Joeman5490
Feb 15, 2011 11:36 PM
1971BB427
Apr 15, 2010 11:08 PM
BLK_CZ28
Oct 13, 2009 11:39 PM
Thoreau
Aug 14, 2009 02:45 PM
hvacben
Aug 21, 2007 01:52 PM
