P0441 in 96 3.8L
Old Aug 14, 2010 | 08:00 PM
REN's Avatar
REN
Default P0441 in 96 3.8L
I have a P0441 code, I did a smoke test and found a leak above the gas tank. Will cutting an access hatch over the fuel pump help seeing a hose that might be cracked? All of the pictures I saw online show only metal fuel lines and no rubber that I would believe where a leak would occur from rotten hose. How far do the metal fuel tubes go until a hose connection is found. Can you reach any tubes through a hatch or should I cut a second hatch closer to the vapor canister?
Old Aug 14, 2010 | 08:44 PM
typeomang's Avatar
The canister can be accessed from the drivers side fender well. take it off and you will have the canister.SFC.......
Old Aug 15, 2010 | 12:33 AM
mrfreez's Avatar
It could also be the purge valve to the cannister as well. I'm less likely to thing it has anything to do with a gas line but rather the evap system itself. As for the leak at the top of the tank is it a line or maybe the seal around the pump housing at the top of the tank that's leaking.
Old Aug 15, 2010 | 01:17 PM
REN's Avatar
REN
I put a new purge valve and canister all the hose were connected to the canister. Must have a loose hose going to the fuel pump.
Old Aug 15, 2010 | 06:28 PM
mrfreez's Avatar
Then check the fuel return line that can throw a P0441 as well.
Old Aug 18, 2010 | 05:16 AM
If you can smell gas be very carful cutting that trap door. Any sparks and it wil ruin your whole day.
97redcamaro
Jul 22, 2011 04:02 PM
antbradley100
Mar 29, 2011 06:08 AM
REN
Oct 18, 2010 08:08 PM
97redcamaro
Jan 4, 2010 09:35 AM
sepadowd
Jun 16, 2007 12:31 AM
