p0300 i cant find the problem 96
Old Apr 14, 2012 | 07:20 PM
BasicConcepts's Avatar
Technical User
ya the only engine that uses an opti is the LT1 you have coil packs. try actually removing the O2s that way the exhaust will go out there and bypass the cats.
Old Apr 14, 2012 | 09:10 PM
Dragracekid's Avatar
now i get what you mean ok ill do that when i get home but about my switching the computer would that do anything because i heard that if you put a 97 in it you can change some settings and such but im not sure if that works on the v6
Old Apr 14, 2012 | 10:12 PM
greenmachine96's Avatar
my bad i thought i was in the lt1/lt4 tech section when i posted earlier.
Old Apr 14, 2012 | 11:41 PM
Technical User
The 96 and 97 computers should be exactly the same
Old Apr 15, 2012 | 06:57 PM
ok so i found 2 problems it was a bad wire on cylinder 5 and also a bad cat so thank you guys for all your help im pretty sure i got it now its running smooth and great thanks again
Old Apr 15, 2012 | 08:07 PM
Technical User
No problem man
Old Apr 15, 2012 | 09:58 PM
looks like i spoke to soon i still have the cylinder 6 misfire only that tho i bypassed the cat is there anything else i can check its still drivable just a missfire sometimes when i stop at a light for a while any ideas maybe a vacuum leak?
calientequack
Apr 12, 2012 07:57 AM
lilLT1
Sep 23, 2011 12:26 PM
bezerker
Feb 2, 2009 12:23 PM
sweet93
Sep 2, 2005 10:19 PM
Camarok
82-92 V8 Tech
Aug 11, 2005 11:20 PM
