p0300 i cant find the problem 96
Old Apr 13, 2012 | 02:39 PM
Dragracekid's Avatar
Default p0300 i cant find the problem 96
i know there are a million threads on this but ive tried everything on them ive been working on the for a few weeks now
my problem went from a p0306 cylider 6 misfire that usually came on at idle and caused a chug chug feeling when i let it roll with no throttle so i thought it may be vacuum but i couldnt find a leak on the way home from work one day it turned into a constand mis running on 5 cylinders and berrly got it home i swapped many parts trying to make it follow but it didnt and it started running really bad multiple misses and smelled like raw fuel out of the exhaust im running out of options im wondering if it is the entire computer please help me and let me know any other info i need to give
ive tried changing
plugs
plug wires
coil paks
injectors
ive checked the fuel preasure at the rail and ive checked the icm thank you so much for any help i dont know what else to try
Old Apr 13, 2012 | 08:11 PM
BasicConcepts's Avatar
Technical User
A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
how many miles are on the car? does the exhaust smell like rotten eggs at all? any other codes?
Old Apr 14, 2012 | 01:14 PM
i did have an egr error before but it doesnt come around very offten
im wondering if it is a faulty cat or cats can i unhook the exhaust and see if it fixes it for a minute?
i also have a good deal on a new computer should i change it because i have a guage app on my phone tourqe im sure you have hurd about it and a few of the gauges dont work like fuel level and fuel rail preasure so im wondering if that is noral or i need a new one
i also want to get a 97 so i can change the computer is that a good idea
Old Apr 14, 2012 | 01:30 PM
also the exhaust smells bad i dont know about bad eggs but it smells like fuel and its got 170k miles i know its asking a lot from the car
Old Apr 14, 2012 | 01:35 PM
Technical User
you can pull the front O2 sensors and see if it runs better, this would indicate the cats are bad
Old Apr 14, 2012 | 03:35 PM
camaroteen82's Avatar
will unplugging the 02 sensers have the same effect as taking them out?
Old Apr 14, 2012 | 03:45 PM
greenmachine96's Avatar
My 96 throws the p0300 with just one cylinder misfiring ive seen it twice, so double check plugs, wires and firing order. Then test the Cam position sensor and go from there. the fuel smell is from the car dumping raw fuel from the misfire. DONt LET IT RUN TOO LONG or you will have to replace the cat for the bank with the or cats if it really is a multiple cylinder misfire affecting both banks.
Old Apr 14, 2012 | 03:58 PM
well i just unplugged them and it seemed to run a little better now tis throwing just one misfire c 5 how do i check the cam position sensor?
Old Apr 14, 2012 | 04:40 PM
Craby probably has the diagram out of a manual he can post if he stops in. but the sensor is part of the opti so if it is bad then you need a new optispark
Old Apr 14, 2012 | 05:37 PM
i thought the optispark was a v8 only thing i dont really know where it is lol
