oil pressure dropping
Old 04-09-2014 | 01:08 PM
camaroteen82's Avatar
Default oil pressure dropping
I just got around to doing the oil change on my camaro and its still losing oil pressure after the engine starts warming. it starts at 110psi and drops down to 90psi after the car starts hovering around 180 degrees and when I park it and let it idle it drops down to 60 psi. whats going on?
Old 04-09-2014 | 01:45 PM
better hook a mechanical gauge to it and see if the readings are correct. what have you done so far?
Old 04-09-2014 | 01:53 PM
if you mean as far as mods just a cai, plugs and wires. nothing that should have messed with oil pressure. I'll see if I can get the shop teacher to let me hook a computer up to it and see whats going on.
Old 04-09-2014 | 02:32 PM
i would look at the oil pressure switch sensor. i thought you changed that though
Old 04-09-2014 | 03:26 PM
You realize it is prefectly normal for oil pressure to drop as the oil get hotter. The oil becomes thinner as it warms up the thinner oil can slip through the noraml bearing clearances faster then the thicker oil.
Your pressures seem pretty high but that is most likely just a bad gage or sending unit. If someone came in with car with the complaint that cold they had 60 PSI oil pressureat idle but warm it was at 30 PSI I would say your car is normal. Even if it happened on a test drive of a new car GM would not touch the car they would simply say it is normal.
The rule of thumb is you need 10 PSI per 1000 RPMS. (at 3000 RPMs you need 30 PSI) Anything less than that can damage your motor. Any oil pressure over 70psi is wasting power.
Old 04-09-2014 | 04:23 PM
I haven't touched the oil pressure sensor yet.
I thought about that gorn except this is the first time it's done it. so I don't know it the sensor started working again or if a spring somewhere is loosing tension when it gets warm.
mexicanpb
01-07-2010 09:25 AM
mrmojorisin6996
02-12-2009 10:36 PM
bFc89
11-24-2008 08:35 PM
dannyAZ
82-92 V6 Tech
06-06-2007 08:01 PM
rombisoid
05-15-2006 01:31 PM
Quick Reply: oil pressure dropping
