oil pressure
Old 01-05-2011, 09:36 PM
Massey's Avatar
Originally Posted by typeomang
I have the 3.8 and believe the oil sensor is located right above the oil filter, is this correct........1SG
Yes it is!
Not all Fram filters are garbage just the ones in the orange boxes. The Tough Guard (grey) are ranked #2 filter behind the Mobil 1.
Massey
Old 01-05-2011, 09:52 PM
sorry guys in the wrong section again. ill go now. :P
Old 01-06-2011, 05:17 PM
typeomang's Avatar
I went and got my usual AC Delco filter and replaced the Fram Tough Guard and the pressure went back to normal. I must have just got a bad one I guess........1SG
Old 01-07-2011, 08:42 PM
mrfreez's Avatar
Originally Posted by craby
freeze the sensor in the oil pan is the oil level sensor. oil pressure sensor on the 94 to 97 is at the back of the intake screwed into the block, the 93 is by the oil filter.
You're right! My bad! I had both sensors break on me at once. The oil pressure sensor os where you said, just above the oil filter.
Old 01-08-2011, 12:04 PM
Well my coolant leak is fixed and now the oil pressure seems to be high. I changed the oil as usual but this time I used a fram tough guard filter (silver) instead of the regular orange fram that I get. The pressure goes to about the second line from the top and down to about half a idle. Could the filter cause a spike in the pressure? I use castrol high milage 10w/30 oil. Thanks........1SG
Different brands of oil filters can produce different oil pressure, depending on how the bypass valve in the filter was calibrated. If the bypass valve in the filter fails to open, the oil pressure will increase until the bypass valve in the engine oil passage opens, usually around 75-80 PSI
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
angelus
02-20-2010 01:17 PM
divineal
10-23-2009 12:21 PM
IBSTROKIN
09-09-2009 10:40 PM
Quick Reply: oil pressure
