oil pressure ?
Old Jan 11, 2009 | 07:19 AM
JaySan's Avatar
Default oil pressure ?
I was replacing my a/c compressor and I accidently broke the oil pressure regulator . I went to Autozone and got the part I needed. Nowmy gauge for oil is like 110 and once is warmed up or started driving for a while its at 90 . Is this normal ? Is this much pressure bad for my car ? Thanx in advance guys
Old Jan 11, 2009 | 08:26 AM
cbr600rx7's Avatar
Default RE: oil pressure ?
You are getting a bad reading. Check your wire connections and insure you have every thing hooked up right.
Old Jan 11, 2009 | 01:20 PM
herestolife1000's Avatar
you car is probably running terribly if that reading is true, but if not then it's probably a bad sensor
Old Jan 11, 2009 | 01:43 PM
Oil pressure regulator? That is a spring and valve internal to the engine. Oil pressure sender, maybe. The wire to the sender may be grounded or the sender isbad.
Old Jan 11, 2009 | 02:52 PM
JaySan's Avatar
yeah then its a sender unit lol . How may the sender be grounded ? Can I fix it ? or should I just buy another part ?
Old Jan 12, 2009 | 10:50 PM
JaySan's Avatar
what should I do next ?
Old Jan 12, 2009 | 11:03 PM
First, make sure you didn't somehow ground the sensor wire out to anything.
Then go back to Auto Zone and make sure they gave you the correct oil sending unit. Even though every counter worker at Auto Zone has a degree in rocket science, one of them could have screwed up! It worked correctly before with the old sensor, it should work correctly now with a new one. If that doesn't do it, then get a different brand of sending unit from another (non Auto Zone) store.
royco95
Aug 2, 2015 10:25 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
angelus
Feb 20, 2010 01:17 PM
divineal
Oct 23, 2009 12:21 PM
IBSTROKIN
Sep 9, 2009 10:40 PM
