Oil change question
Old Dec 14, 2010 | 12:57 PM
H2C's Avatar
H2C
Default Oil change question
Im changing the oil for the first time in my 97 3.8 auto, (castrol gtx 10w-30)
Its not my first oil change or anything but are there any special systems or procedures that i need to be careful of?
Old Dec 14, 2010 | 01:21 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Nope. Just drain the oil from the pan til it stops coming out then remove the oil filter (which is super easy on 3.8's). The only thing I do when changing oil is dipping my finger into the new oil and spreading it on the new oil filters o ring so it doesn't seize.
Old Dec 14, 2010 | 01:32 PM
H2C's Avatar
H2C
Yeah thats where you spread it onto the rubber ring on the new filter right? and you HAND TIGHTEN ONLY right?
Old Dec 14, 2010 | 01:49 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Correct.
Old Dec 14, 2010 | 01:58 PM
Massey's Avatar
yes make sure you put the new oil on the filter gasket or it will grab and pull off the ring. This is really bad since all your oil will be pumped out of the car in less than a block. Then only tighten the filter 1/2 turn after the gasket makes contact with the filter mount.
Massey
antperri1222
Mar 20, 2013 06:25 PM
NYH1
70-81 V8 Tech
Nov 10, 2010 11:32 AM
00BlackBullet
LS Series Tech
Dec 10, 2006 07:42 PM
JaySan
Jul 9, 2006 10:48 AM
