Cam change question??
Old Nov 4, 2010 | 02:45 AM
NYH1's Avatar
Default Cam change question??
I'm just kinda thinking out loud here.
I'm currently using this cam in my 385 stroker, in sig. below. It has lighting quick responds, bruttle low end and mid range torque. It's a GREAT street cam in my setup and pulls pretty well up to 56/5800 RPM.
•PT# 60102 Voodoo 262/268
•Advertised Duration (Int/Exh): 262/268
•Duration @ .050 (Int/Exh): 219/227
•Gross Valve Lift (Int/Exh): .468/.489
•LSA/ICL: 112/108
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 1400-5800
I was wondering how much more power this cam will give me with my current setup. Will I lose much low end torque and/or any responsiveness with this cam?
•PT# 60103 Voodoo 268/276
•Advertised Duration (Int/Exh): 268/276
•Duration @ .050 (Int/Exh): 227/233
•Gross Valve Lift (Int/Exh): .489/.504
•LSA/ICL: 110/106
•RPM Range: 1800-6200
•PT# 60103
Again, I'm just toying with the idea. What do you guys and/or gals think? Setup is in my sig. below.
Thanks, NYH1! :bowtie:
Old Nov 4, 2010 | 11:48 PM
1976camaro's Avatar
im not to sure but i think around 10 or 15 more hp you have a good amount with that camp....I actaully have a question for you haha... I replaced my timing chain and gears the other day and if your lookin at it from the front the left side is super tight and the right side is kinda loose is that normal
Old Nov 6, 2010 | 06:26 PM
NYH1's Avatar
The chain tension should equal out on both sides after everything spins around a few times.
Old Nov 9, 2010 | 10:17 PM
1976camaro's Avatar
ok thanks i wont be able to fire her up until i replace my oil pan gasket that my dad broke haha the groove peice that gooes inside the timming cover got ripped out
Old Nov 10, 2010 | 11:13 AM
A bigger cam will only give more power if the heads can feed it. Otherwise it may accomplish nothing or even cause the power to go down. Head and cam characteristics need to be matched for best results.
Old Nov 10, 2010 | 11:32 AM
That's nothing at all to be concerned about. One side has more tension on it because of the direction you were rotating the engine. One side will be tight because of the pulling load, and the other side will have slack. It's the same as on a bicycle, when pedaling, the top of the chain will be tight because of it pulling while the bottom has slack.
antperri1222
Mar 20, 2013 06:25 PM
H2C
Dec 14, 2010 01:58 PM
00BlackBullet
LS Series Tech
Dec 10, 2006 07:42 PM
JaySan
Jul 9, 2006 10:48 AM
