No Turn Signals
Old 08-23-2009, 07:34 AM
New2Camaro's Avatar
Originally Posted by shawnathan
sounds like u need some blinker fluid to me
That's what we tell truck drivers who forget to turn their turn signals off to turn them off b4 they run out of blinker fluid. I was at an Advance Auto store one day and a lady came in and needed a headlight so her smart alec husband told her to get some headlight fluid and she believed him.
Old 08-23-2009, 08:59 AM
New2Camaro's Avatar
Originally Posted by 02StanGT
i'm going to say the signal flasher under the dash. it is separate from the hazards.
Where the heck is the flasher located under the dash? Jeez why can't these car makers make stuff simple like they used to.
Old 08-23-2009, 10:40 AM
dont know what yr u have but mine is under the dash by the dignostic plugin. above it up the stearing column, need to take the plastic off.
Old 08-23-2009, 01:04 PM
New2Camaro's Avatar
Yeah I didn't see anything by the diagnostic plug when I was looking this morning. I'll look again when it stops raining. Thanks.
Old 08-23-2009, 06:54 PM
gotta take the plastic cover thats under there. its called a knee bolster but i think of it as the under part of the dash. need to go up the column about 8 inches (i think) from the dignostic plugin.
Old 08-24-2009, 06:53 AM
Xx3800xX's Avatar
i haven't heard that one in a long time! I second that notion, if your fluid is low you will have a slow blink or none at all!
Old 08-24-2009, 09:54 AM
Jonny Dubyah's Avatar
Hmm..maybe ill pick some up..can i get that at napa? LOL
Old 08-28-2009, 06:48 PM
Posi's Avatar
Mine just stopped working. When I put on the turn signal, the rear turn signal lights come on but won't flash. Just replaced the flasher and they still wont work. Any ideas? Bulbs and fuses are fine.
Old 08-28-2009, 06:58 PM
Posi's Avatar
Is the hazard flasher on the left side of the column and the blinker flasher on the right? Also, are they separate parts or if you buy a flasher will it work for both? Thanks.
  #20
Old 08-28-2009, 07:35 PM
02StanGT's Avatar
you have the locations correct, and i believe they are different part numbers
Quick Reply: No Turn Signals
