No Heat?
Old Dec 11, 2008 | 11:01 AM
TheGrimReaper73's Avatar
Default No Heat?
i have no heat.. only air... and all the vacuum lines are sealed.. but there is a hose running to near where my ac compressor " was " and i cant see where it goes? any suggestions?
http://i76.photobucket.com/albums/j2...3/DSC01958.jpg
Old Dec 11, 2008 | 11:03 AM
Saint_Ali's Avatar
Default RE: No Heat?
your heater core may be plugged
Old Dec 11, 2008 | 11:08 AM
well what my friend who knows a lot about cars said that that hose is the heater hose.. but we arent for sure where the hose goes.. but that's why i am not getting no heat he said.. .. and i cant like get to the heater core area easily either but if my thermostat was plugged maybe my heater core is plugged also :/
Old Dec 11, 2008 | 11:17 AM
Saint_Ali's Avatar
you have heater lines and you have a heater core,which is under the passenger side dash
Old Dec 11, 2008 | 11:36 AM
There should be two hosesconnected to the heater core. The other ends usually connect, oneto the water pump, and the other to a water passage. Since you didn't mention what year and engine you car has, it is pretty difficult to look up the hose routing.
Old Dec 11, 2008 | 11:38 AM
its a 1994 3.4.. and the water passage? i just know the hose just sits there.. does nothing.. does not leak as i know of.. and soon ill get underneath my passenger side dash like alih said and see what i can do
Old Dec 11, 2008 | 12:28 PM
In your other post you said you pulled out your thermostat. That's your problem, since now the coolant isn't hot enough for putting out sufficient interior heat.
Old Dec 11, 2008 | 12:37 PM
yeah true... but i haven't had heat ever.... and so tired of it lol.. to cold to be trying to drive and change gears lol.. but ill replace thermostat in few days and then i will see if that helps
Old Dec 12, 2008 | 07:53 AM
RSSteve's Avatar
Yeah, your never going to have heat if you don't havea thermostat in it.... Also have you checked your coolant level in the radiatior? Also is that hose connected to anything or just sitting there? If it is a heater hose like your friend says then you definantly don't have any coolant becuase it would all have leaked out but you would have an over heating problem as well.
Old Dec 13, 2008 | 12:14 PM
yeah i will get a new thermostat here in a few days and put it on and RSSteve.. like the hose is just siting there.. and there is some orange corrosion in it.. if that helps? and well at one point the car didn't even come close to overheating for over 4 months.. its just my thermostat messed up lol and which it kept throwing water and antifreeze out of the resavoir
c4maro
Feb 10, 2011 08:21 PM
92RS FTW
82-92 V8 Tech
14
Nov 26, 2010 07:37 AM
burning camaro
Nov 9, 2010 06:15 PM
sl1foru
Nov 10, 2007 10:16 AM
FullThrottleChick
Dec 6, 2005 09:59 AM
