No Heat?
i have no heat.. only air... and all the vacuum lines are sealed.. but there is a hose running to near where my ac compressor " was " and i cant see where it goes? any suggestions?
http://i76.photobucket.com/albums/j2...3/DSC01958.jpg |
RE: No Heat?
your heater core may be plugged
RE: No Heat?
well what my friend who knows a lot about cars said that that hose is the heater hose.. but we arent for sure where the hose goes.. but that's why i am not getting no heat he said.. .. and i cant like get to the heater core area easily either :( but if my thermostat was plugged maybe my heater core is plugged also :/
RE: No Heat?
you have heater lines and you have a heater core,which is under the passenger side dash
RE: No Heat?
There should be two hosesconnected to the heater core. The other ends usually connect, oneto the water pump, and the other to a water passage. Since you didn't mention what year and engine you car has, it is pretty difficult to look up the hose routing.
RE: No Heat?
its a 1994 3.4.. and the water passage? i just know the hose just sits there.. does nothing.. does not leak as i know of.. and soon ill get underneath my passenger side dash like alih said and see what i can do
RE: No Heat?
In your other post you said you pulled out your thermostat. That's your problem, since now the coolant isn't hot enough for putting out sufficient interior heat.
RE: No Heat?
yeah true... but i haven't had heat ever.... and so tired of it lol.. to cold to be trying to drive and change gears lol.. but ill replace thermostat in few days and then i will see if that helps :)
RE: No Heat?
Yeah, your never going to have heat if you don't havea thermostat in it.... Also have you checked your coolant level in the radiatior? Also is that hose connected to anything or just sitting there? If it is a heater hose like your friend says then you definantly don't have any coolant becuase it would all have leaked out but you would have an over heating problem as well.
RE: No Heat?
yeah i will get a new thermostat here in a few days :) and put it on :) and RSSteve.. like the hose is just siting there.. and there is some orange corrosion in it.. if that helps? and well at one point the car didn't even come close to overheating for over 4 months.. its just my thermostat messed up lol and which it kept throwing water and antifreeze out of the resavoir
