New Guage location.
Old Sep 3, 2007 | 08:12 PM
Chappie99's Avatar
Default New Guage location.
I spent half the day installing new guages. I didnt want to go with the piller post look, everybody does that, so I was looking for a differnt place to put them.
[IMG]local://upfiles/7064/BD7734813995496289B9F21E1B351470.jpg[/IMG]
Old Sep 3, 2007 | 08:22 PM
02StanGT's Avatar
Default RE: New Guage location.
Looks good man.
Old Sep 5, 2007 | 09:08 PM
Iceman1023d's Avatar
that looks good... all that space seems to do in my car is collect spare change and garbage
Old Sep 5, 2007 | 09:13 PM
ohh and what are they for?
because i was thinkin about gettin some... but i didnt know what ones to get
Old Sep 5, 2007 | 09:20 PM
meteoralp45's Avatar
not too shaby, i like it,, that space in my car is taken up by a remote for my cd player, which i have no ****in clue why it came with one, ive used it once and bout wrecked
Old Sep 5, 2007 | 09:22 PM
haha.... i think my remote is stuffed in there somwhere too... and i dont use it for the same reason
Old Sep 6, 2007 | 05:24 PM
mloaks's Avatar
ORIGINAL: 02StanGT
Looks good man.
2x^
Old Sep 9, 2007 | 06:52 PM
Chappie99's Avatar
Those are oil psi and water temp.. They are mechanical guages.. The only problem is that on the oil pressure, you need to add a T fitting so you can still use your electric oil sending unit that came with the car. If you disconnect the stock wires, it will read no oil psi and your "Check Guages" light will stay on..Same with the water temp.. For the oil, I went to home depo and bought a 2" pc of 1/2 black threaded pipe and a 1/2 T fitting.. You have to install it with the T facing up. Meaning that its longer than wider..If you do it the other way, you wont have clearance for the original O.P.S.U oil pressure sending unit. Its an easy job.. The guages were $12.99 each at V.I.P and the fittings were like less than $2.00 But if you do install the oil pressure guage.. DONT USE THE PLASTIC LINE that is supplied with the unit. Spend the extra $$ and get the copper 1/8 tubing with all the fittings..Its an extra $10..Oh ya, dont forget to use Teflon tape, or it will leak.
ORIGINAL: Iceman1023d
chevyguy912
82-92 V8 Tech
Jan 9, 2012 05:16 PM
MKCoconuts
Jan 4, 2012 12:56 PM
camarofreak1990
Jul 5, 2008 10:27 PM
74Z28
May 25, 2007 11:31 PM
saikali
Mar 26, 2007 11:36 PM
