need help gas problem
Old May 27, 2010 | 06:50 PM
jj350's Avatar
ya I have some more info when i start my car after a few hrs it blows out black gray smoke and it smells like gas. What can this mean?
Old May 27, 2010 | 09:00 PM
libertyforall1776's Avatar
Get your injectors NOID tested... Any codes/SES light?
Old May 27, 2010 | 09:06 PM
jj350's Avatar
no check engine light but can i still scan. and how do i get it noid tested
Old May 27, 2010 | 10:07 PM
pick up a noid test light at the local parts store. u plug it into your injector wire and if the computer is telling the injector to fire it will blink.
Old Jun 2, 2010 | 10:49 AM
jj350's Avatar
Hi I solved the back firing problem, it it was my spark plugs lol . I am not sure if it solved my mpg problem. I has not tested it yet. I had another question to ask, what controls the radiator fan? my fan never comes on i have replaced the relay but it still wold not come on.
Old Jun 2, 2010 | 11:05 AM
the ecm turns the fans on. the temp sensor tells the computer what the temp is. if u unplug temp sensor the fans should come on. if not the fans have a wiring problem or the fan is failing.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
