Mystery 95
Old 05-22-2011, 04:29 PM
Pumps wear out with time and run slower as the bearings wear, there is also a check valve in the fuel pump that can go bad and create the hard starting problem, Get a pressure gage and chek the fuel pressure and regulator function.
Old 05-22-2011, 05:16 PM
mrfreez's Avatar
NGK plugs are also very good. Like you guys, I haven't had good luck with Bosch.
Old 05-27-2011, 06:23 PM
im swapping out my bosch platinums tomorrow for old acdelco came stock with the car. did the lumina have a bad high idle cause of the plugs?
Old 05-27-2011, 07:43 PM
i would do a fuel pressure test before so i knew what i had to start with. it could be that is not getting enough fuel or too much fuel. will it start easier if you hold the throttle down a little. that would add air and lean the mix a tad. mine runs rich when cold and if it doesnt start right away i have to hold the throttle open a tad before it will start. its just that one time when its cold though
Originally Posted by Michael Smedley
Yes, this problem was there before i did the plugs. I installed the AC Delco plugs and new wires when i first started to troubleshoot this problem.
omr
10-25-2014 07:02 AM
vern_e_jon
11-16-2009 06:43 PM
Racerx11
07-24-2009 05:49 PM
Noxzima
11-26-2008 04:52 PM
thirdgencammyman000
82-92 V8 Tech
04-29-2008 01:33 PM
Quick Reply: Mystery 95
