My rattle..it has become my nemesis
Old Sep 27, 2012 | 09:05 AM
Nebraskaborn's Avatar
Your thread is what had me take the video of the flexplate. I checked all the bolts..everything was great. Not even a scrape on the flexplate or bolts. I was even preparing myself for the worst. Any other ideas on where to troubleshoot?
If I pull off the y-pipe will I be able to see if the inner pipe is loose?
Old Sep 27, 2012 | 09:21 AM
AboveTheLogic's Avatar
Hmm, maybe there is an issue with the flexplate to crankshaft bolts, IIRC there are 6. If you unbolt the converter from the plate and slide the converter back you might be able to see them. That may be a wild guess, though.
I'm trying to think of what inner pipe you are talking about. You think it might be the cat?
Old Sep 27, 2012 | 10:18 AM
The y-pipe is supposedly double walled..and the noise could be from the inner rattling against the outer..thats what I have read here and the garage told me that.
The catalytic converter is brand new..$225 mistake the noise didnt change.
If those 6 bolts were loose wouldnt I have a rattle even at idle?
Old Sep 27, 2012 | 11:01 AM
hmm, I've never heard of that but that doesn't mean much
I think if it was the y-pipe, you could grab it with some thick gloves and maybe feel the rattle or possibly make the noise go away.
I'm not sure what you'd experience if the 6 flexplate to crankshaft bolts were coming loose. Mine were nice and snug when I had my issues, I'm just trying to think of things to check.
Old Sep 27, 2012 | 11:23 AM
it isnt there at idle only on acceleration. I am changing valve covers as we speak so ill pull y pipe just to see.
Old Sep 27, 2012 | 11:24 AM
random question..is the front plug on passenger side supposed to have a metal protector on the boot?..it is occasionally sparking on the manifold..obviously needs fixed ..but do i need the metal protector?
Old Sep 27, 2012 | 11:40 AM
Is it close to the exhaust manifold? I'd leave it there, it is probably shielding the wire from the exhaust heat.
Old Sep 27, 2012 | 11:52 AM
You have a bad spark plug wire, get a new set. The metal shield is there to prevent the wire from being melted from the exhaust manifold, but you should not have any arcing to ground. Your wire or boot is "leaking" and is conducting through the shield.
Old Sep 27, 2012 | 01:35 PM
ok got the intake completely off. found some hard carbon underneath right where the head meets the block..good idea to change head gaskets?
When I pulled the heater hoses and thermostat housing i got less then 2 gallons out of the bottom of the radiator...that is not right..is it?
Old Sep 27, 2012 | 01:41 PM
  #20
just checked the rear plug on passenger side was loose....I just bought this car...I love PO presents.
