missing when hot
Old 04-07-2011, 05:20 PM
3800camaro's Avatar
Sounds like your coil packs must be going. Missing at higher rmp is normally a sign they are going.
  #22
Old 04-08-2011, 03:09 PM
duane18's Avatar
coil packs are new. just put them in and they made a big difference in the way the car drives.
  #23
Old 04-08-2011, 03:11 PM
duane18's Avatar
Originally Posted by Chaotic94
When My timing cover gasket blew, I drove the car without any antifreeze for a mile to get it home. The temp gauge was pegged way over 260. All it did was blow out my head gaskets. Bar's leak fixed me up and I've been driving it ever since then.
what bars leak did you use? i tried the kind thats 30 bucks and 1 step
  #24
Old 04-08-2011, 06:58 PM
Chaotic94's Avatar
September 2011 ROTM
That's what I used. When you put it in, let the car run til it gets hot, then let it cool completely down. Then let it run again til it gets hot. Then let it cool down. It's the heating and cooling over and over that gets the Bar's leak to the leak spot in your coolant system and seals it up.
  #25
Old 04-08-2011, 09:31 PM
duane18's Avatar
oh damn i only did it once :/
  #26
Old 04-09-2011, 11:05 AM
Chaotic94's Avatar
September 2011 ROTM
Keep doing it. On a day off run it for 15 minutes, let it sit for an hour or so, then run it again for another 15 minutes and let it sit for an hour or so. Do that over and over and over again all day. On the next day you should have it fixed.
  #27
Old 04-09-2011, 06:20 PM
duane18's Avatar
ok ill try it again. and another thing my car sounds like it cammed and has a horrible eye burning odor coming from the exhaust. what could this be
  #28
Old 04-09-2011, 06:34 PM
3800camaro's Avatar
Could be coolant burning. Is there white smoke? Or blue if it's burning oil.
mike6208
07-25-2011 04:47 PM
Zaerath
12-06-2009 12:13 PM
aboston
02-12-2009 10:16 AM
stonecoldtrk
12-19-2008 10:18 AM
Phil
12-28-2006 06:40 PM
Quick Reply: missing when hot
