LT1/LT4 Tech 1993-1997
Car Missing
Old Dec 28, 2006 | 04:54 PM
Phil's Avatar
Default Car Missing
I have a 1995 Z28.. and you can really notice the miss low rps in 5 and 6th gears.
I've had injector problems cauing the car not to start. got them cleaned and now the car is running but not good.When i got thecar started only 6 or 7 injectors were working.ive claned the injectors twice and put 2 cans of seafome in it and hope they all clean out and start working.
The car had been sitting for over 5 years before running. My dad says he thinks it feels like the spark plugs. so today we are going to change the spark plugs and see if it does any help
So what do you all think??
Spark plugs? or 1 or 2Injectors dead?or something else??
also. the check engine light is on..
Thanks
- Phil
Old Dec 28, 2006 | 06:12 PM
KoRN_Munky's Avatar
Default RE: Car Missing
well if i was you id replace plugs wires coil OPTISPARK and fuel filter clean the EGR and maf and map sensors
Old Dec 28, 2006 | 06:40 PM
Definetely change the plug wires with the plugs, if nothing else to avoid going there again. Also get the best plugs & wire you can afford, for the same reason.
mike6208
Jul 25, 2011 04:47 PM
duane18
Apr 9, 2011 06:34 PM
Zaerath
Dec 6, 2009 12:13 PM
aboston
Feb 12, 2009 10:16 AM
stonecoldtrk
Dec 19, 2008 10:18 AM
