Misfire Problem P0305B How do I fix this???
Old May 9, 2007 | 08:58 AM
usarmyrangrs's Avatar
Default RE: Misfire Problem P0305B How do I fix this???
Well, yes, there is compression ratio, as you stated, but there's the actual compression reading, which is read in psi. The aforementioned compression numbers (100psi) seems a little high for a 3.8.
Old May 11, 2007 | 04:44 PM
hrankarl's Avatar
I FIXED IT partially
i put a new coil in it for cylinder #5 and #2. it runs fine now.
with the exception of a hesitation to start sometimes.[:@]
But no more misfires
thanks for all your help
Pidi
LS Series Tech
Mar 16, 2012 02:05 PM
thegad
82-92 V6 Tech
16
Jan 6, 2010 09:05 AM
BIGMIKE
Aug 9, 2009 07:22 PM
dangerjakeray
Jun 2, 2009 12:32 PM
Rmlink
Apr 14, 2009 07:56 PM
