Maf is nasty!!!!
Old Nov 8, 2010 | 10:09 PM
texas_RS's Avatar
Default Maf is nasty!!!!
ok so my MAF sensor is super dirty and im gonna pull the TB, MAF, and intake manifold off and clean all of them but my MAF is horrible. i was told the only SAFE way to clean it is rubbing alcohol and a Q-tip... VERY CAREFULLY that is. is that how?
Old Nov 9, 2010 | 11:44 AM
Massey's Avatar
They make special MAF cleaners that can clean them up really good without touching the sensor. I would not touch it if you dont have to. They are not cheap to replace. Why take the intake manifold off? That is alot of work and cheaning the grime off will not really give you any more ponies. Chean the TB and MAF you should be OK. Make sure that the IAC is clean too (If you have one)
Massey
Old Nov 9, 2010 | 12:32 PM
As Massey said, use a spray MAF cleaner, and you can buy it at a parts store. The sensors have some fine wires to them, and you don't want to go poking around and break them. The spray cleaner alone works well, I've used it many times before.
Old Nov 9, 2010 | 03:21 PM
texas_RS's Avatar
alright,when i took my MAF out, the prongs holding the wires together are all bent sideways and the wires are wavy (not straight across) should i straighten them out carefully or just buy a new one... if i break it imma have to buy a new one anyways!
Old Nov 9, 2010 | 08:07 PM
BasicConcepts's Avatar
Technical User
deff try to fix theres no need to spend all the money if you can fix
Old Nov 9, 2010 | 11:02 PM
texas_RS's Avatar
i fixed it, my car has a notible more amount of pep since its fixed... now to take off and clean the TB
thatcamaro
Oct 25, 2011 09:09 AM
kmferzola
Mar 29, 2009 01:42 AM
sprtsfrk
Dec 3, 2008 03:26 PM
chewybacca11
Jun 19, 2008 03:45 PM
