Losing coolant near top of engine 3.8L
thanks Gorn. The photo works on my home computer. Autozone says its dealer part. Advance says I have to buy the whole belt tensioner pulley assembly $75. Couldn't find it on GM parts direct. I did get a look at the one that came with the assembly at Advance & looks like the one in the photo. Black plastic about 5/8" ID with an o-ring on each end. I'll keep looking. Any ideas?
Thanks for your help, the leak is fixed! Hard to believe GM puts all those cast aluminum parts together with one weak piece of plastic. Now that I've got that off my chest...it did last 14 years... Two photos: 1) the ugly mess behind the tensioner, fried coolant, intake gasket okay, 2) the culprit, disentegrated elbow. The ends of the elbow and the o-rings were still in the intake & tensioner. Bought part from dealer $12. Works now. Thanks again for your help. It was driving me batty trying to figure it out. Intake seals look okay.
I am doing this job too . The belt tensioner assembly has an outlet that goes into the water pump block that uses an o-ring seal . I want to replace that o-ring too . The exist o-ring is distorted I would reuse it anyway What size is it ? The large end of the extra fitting (that I don't needed wit) in the Dorman kit has purple o-ring on one end that looks close in size but I want to get the right one . - Thanks
I am doing this job too . The belt tensioner assembly has an outlet tat goes into the block that uses an o-ring seal . I want to replace that o-ring too . What size is it ? The large end of the extra fitting (that I don't needed) in the Dorman kit has o-ring on one that looks close but I want to get the right one . - Thanks
The o-ring bore of water pump ( WP ) seems to have a little roughness ( RTV resdue, O-ring residue, bars leaks ?) that I cna't get off with my fingernail, stiff toothbrush and brake cleaner . I want the seal area to be petfectly smooth (no scratches). I guess that I will try gasoline next then maybe or 400 grit wet/dry sandpaper.
Would it be OK to use a little permatex orange copper RTV sealant along with the o-ring to make sure there is a good seal ? Normally I wouldn't do this with o-ring seals but maybe it is appropriate here .
- Thanks
- Thanks
Artist_X
Aug 17, 2009 11:18 PM
