loose door panel
Old Feb 26, 2011 | 08:12 PM
Adooley's Avatar
Default loose door panel
I just bought a used Camaro ('94 v6) and one of its issues was that the door panel is loose on the passenger side. I can get the glue for it for 50 and rent the gun for 10 from a local Napa. I was just curious to see if anyone else ran into this issue?
Old Feb 26, 2011 | 08:34 PM
interior panel or door skin?
Old Feb 26, 2011 | 10:12 PM
Adooley's Avatar
I guess it would be the door skin. (the exterior) The guy at my local shop said it was a common problem with these cars though I've never really heard about it. I'm just trying to figure out if it is as straight forward as it sounds to fix.
Old Feb 26, 2011 | 10:16 PM
3800camaro's Avatar
Take the panel off and bring in one of the clips to your local auto parts store. Do not glue as it'll make it very difficult to remove if you want to upgrade speakers or have problems with you locks or windows. If it's you plastic behind the panel then pick up a tube of acoustical sealant and go around the frame pressing the plastic back on.
Old Feb 26, 2011 | 10:54 PM
Massey's Avatar
If you are talking about the door skin then you can glue it back together using the special SMC adheasive. This was not a common thing with these cars unless some one was trying to break in. This was easier and faster than a slim jim you just pull on the door skin and it would pop off the frame and then reach in and release the lock by hand. I cant remember how many I fixed when I was an Autobody tech. Make sure to use "C" clamps and or vice grips to hold the panels back together as tight as you can. Oh and use some wood paint sticks to protect the paint as well.
Massey
Old Feb 27, 2011 | 11:02 AM
Adooley's Avatar
Thanks Massey, that sounds good and I'll do my best and I'm looking forward to doing. I'll let you fiys know how it goes!
J-Factor
Feb 20, 2015 12:37 PM
muaymendez1
Jan 8, 2011 07:32 PM
94z28chevy
Jun 8, 2008 06:42 PM
94z28chevy
82-92 V8 Tech
Jun 5, 2008 07:58 PM
GoofieJ21
Oct 3, 2007 12:08 AM
