Light miss/sputter at low speed
2001 Camaro, Auto trans, 3800v6, appx 140,000mi. Drives fine, starts fast, but at anything under 10mph still in 1st gear there is a miss. feels like it goes from getting fuel to having none at all, dosnt die just is annoying.
I know the normal routine, Fuel system filth/buildup, fuel filter, pump cutting out.. But im not a gas motor guy much less a camaro guy so if theres anything common on these cars that will cause this i would like to know before i go through everything.
Also tell me alittle about the fuel system, Is the pump in tank or not? Where is the filter? any known problems?
