94 Cmaro V6 sputter?
Old Jun 17, 2009 | 01:42 PM
Rigit's Avatar
Default 94 Cmaro V6 sputter?
I purchased this car about three months ago. It has ran just fine up until now. It has always taken a second or two to crank. Now, once started, it will sputter a bit and a heavy sputter if I get on it. Toying with the peddle will get me on down the road though. After about three miles or so everythings seems fine. No sputter and I can get on it fine. Can any of you guys help me with this. I use this car to comute back and forth to work. Oh and BTW, I live in south GA and the temp was in the 70's when I bought the car it now reaches the 100's, but my problem happens at all times of the day.
Old Jun 18, 2009 | 02:19 AM
outta_control_z28's Avatar
so when the car warms up it runs ok ?
Old Jun 18, 2009 | 03:38 AM
RFxCamaro's Avatar
check your egr valve or maf i had a similar problem and try to see if theres any codes
Old Jun 18, 2009 | 06:35 AM
Rigit's Avatar
Correct, it runs fine once it warms up. Usually just a few miles down the road.
I will take it by autozone today at lunch and have theme run the computer on it. I'll let you guys know what comes up.
Old Jun 18, 2009 | 07:31 AM
Rigit's Avatar
How do I inspect the EGR valve to find if it's faulty? Can this part be cleaned or must it be replaced?
Old Jun 18, 2009 | 07:07 PM
Rigit's Avatar
Okay, I capped off the EGR valve using a coke can and presto, no sputter. I only went a mile or so down the road, but it hasn't run that well since I bought it. Now it did make a pop once when I got on it. Idk, maybe a backfire, it has a flowmaster on it. I did not notice anything else.
Question, is it safe for the engine to leave capped until I can hunt down a good used EGR?
Old Jun 19, 2009 | 01:16 AM
there are a couple 94s being parted out on this site. may have one. try posting in the for sale section what u are looking for. egr is for polution control. should be ok.
Old Jun 22, 2009 | 03:36 AM
RFxCamaro's Avatar
good to hear that you traced it to the egr is it trowing a code? check it, mine was a stuck pintle i took some brake cleaner to it and no more problems make sure u get every nick and cranny, i think it just wont pass smog with a capped egr but dont quote me on that
Old Jun 22, 2009 | 09:28 AM
Rigit's Avatar
BAD NEWS
The sputter is back. Like I said, capped the EGR and ran it a few miles, everything seemed fine. Then I ran it two or three miles the next morning and it was fine. Come lunch time I get in it to head to town and it goes to sputtering again. Just like before, after a few miles everything is smooth. I have noticed it idleing rough and low now. IDK. I can't figure it out.
If anyone has anymore suggestions, please feel free to share. Thanks.
Old Jun 22, 2009 | 02:15 PM
by capping off your egr when your cruising your car opens the egr to cool the cylinders down and to reduce nox emmisions when u delete the egr you cylinder temp rises and could cause detonation due to overly hot cylinders and your cars emissions goes down the tubes but if the car is cold and drove in stop and goe traffick you wouldnt notice it cause the egr wouldnt be open i suggest get a new egr valve and slap one on i run a parts store andcould see iff i could get ya a good deal one one
bMoRe
Mar 29, 2012 11:55 AM
heavychevy
May 15, 2011 12:10 PM
xXChipXx
May 7, 2011 03:31 AM
Rigit
Jul 14, 2009 08:14 PM
93camarofreak
Apr 9, 2008 05:10 PM
