L26 heads
Old Dec 20, 2010 | 07:09 PM
1998camarossclone's Avatar
Default L26 heads
ok so i was at the junkyard for work and i stumbled across 6 05 police impalas. all with 3800's. now, my question is are these equipped with the L26 3800? the ones with the rumored larger valves, really cant tell but i would think so because there 05 models, but theres no engine cover cause its a law enforcement vechicle. i snagged the high voltage alternator and bracket. but can somebody tell me before i go back out there and pull these things off for no reason
Old Jan 23, 2011 | 01:53 AM
texas_RS's Avatar
im not 100% on this but i did read a post on here that said the heads on that motor are bigger and will help with power, i would say it'd be a good thing to do from what ive ead but like i said i have no personal experience and i am not 100% on this
Old Jan 23, 2011 | 02:23 AM
Massey's Avatar
The Series III or L26 head has a .030 larger intake valve. Yes it will help with power but you are also going to have to realise that .030 is only the thickness of a dime. You will have marginal gains with the heads by themselves, the main source of the gains will be in your gas tank.
Massey
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
