Just got my new muffler.
Old Feb 8, 2007 | 11:45 PM
98LS1Camaro302's Avatar
Default Just got my new muffler.
Just got a new muffler put on, the car is a 2000 3.8 Series II 5 Speed.
The shop said it was an 80 series but I think its not after reading. The 80 series are supposed to be quiet rite? Well mine is pretty loud. It is a dual out, inlet/out on one side, and an out on the other. The car sounds NICE almost like a V8 at idle and nice at lower RPMs. However, at higher RPMs it is a little Raspy. Also, when letting of the gas at higher RPMs, it is purdy raspy to and "bumbles a lot" . The car is stock, if I install a glasspack or resonator after the cat would it take away from the Rasp? Or maybe larger pipes? Also no tips are on it yet, do they make any difference? Thanks.
Old Feb 8, 2007 | 11:59 PM
badinfluenceRS's Avatar
Default RE: Just got my new muffler.
80 series is the dual outlet...its not supposed to be quiet
a v6 is always gonna have a little rasp...headers, high flow cat, and larger diameter/mandrel bent exhaust tubing will help reduce the rasp
Old Feb 9, 2007 | 12:01 AM
Ite, what is the stock tubing size? WOuld a 2.5 upgrade help? How would the High Flow Cat be on emissions? Also, will an intake hcange anyhting?
Old Feb 9, 2007 | 12:10 AM
bluovlh8er's Avatar
when i put my 80 series on it took like 2 weeks to break in. it will get a lil louder and lower but not much.
Old Feb 9, 2007 | 12:16 AM
Yea I figured after a lil time it would change, but I guess Ill try the cat back then headers and see where that takes me.
Old Feb 9, 2007 | 12:24 AM
2.25" is stock..
Old Feb 9, 2007 | 02:21 PM
jhop16's Avatar
mines got 40 series w/ 3 inch pipe... i never noticed any rasp? but idk what it sounds like
Old Feb 9, 2007 | 03:35 PM
Rasp is kinda like the buzzing sound when you let off at higher RPMS.
Old Feb 11, 2007 | 04:41 AM
JHL88's Avatar
dam i put a 50 series flowmaster on mine w/ single in and out and i dont have any rasp at all, i guess it depends on the muffler
Old Feb 11, 2007 | 11:44 PM
sooperdewd's Avatar
That Rasp I dont know if its wit hthe exhaust as much as it might be with the aluminum plate behind the muffler. Mine would make a "rasp" buzzing sound like they said even at idle till it was warmed up I went under and looked at it, and there is a thin piece of metal the covers teh underside where the T-tops are held to where the actual muffler is at, maybe its a head shield alll I know is I went under and the sides of it stick out, I jsut bent em up and it doesnt buzz anymore lol might just be mine. The only other rasp I can think of is done at like 3 grand in second gear only if Im not hammering the gas, I haear a buzzing cruising there, I think I just need a new flywheel thats what it sounds like to me.
Toxic
Apr 15, 2012 09:20 AM
Eric89RS
Jun 9, 2007 01:24 AM
Jims94LT1
Feb 11, 2007 12:42 PM
maxxiepad
Feb 9, 2007 07:12 PM
98LS1Camaro302
Feb 7, 2007 12:51 AM
