Just Died
Old Aug 21, 2010 | 08:41 AM
mrfreez's Avatar
Have you checked the IAC motor? Check the EGR for a vacuum leak too.
Old Aug 21, 2010 | 12:20 PM
Massey's Avatar
98 could be TBW but most of them are cable driven. You can check the TPS also with an OHM meter, the older analog ones work best for this since they are more sensitive to dead spots in the TPS resistor inside. Just find the 2 posts that will read the resistance from the wiper to the resistor and then slowly move the TPS. The needle should move without jumping as you open the throttle. If it jumps up or down then you have a bad TPS. You can also use a digital Ohm meter to do the same check but you need to use one that has a very high sample rate or the numbers will be jumpy anyway.
Massey
1976camaro
70-81 V8 Tech
65
Sep 17, 2010 01:36 PM
Swiftpain
Aug 12, 2010 04:52 PM
Lilspleen
Nov 24, 2008 11:22 AM
95Camaroman
Nov 15, 2008 08:41 AM
jimidude87
82-92 V8 Tech
Apr 14, 2008 10:25 PM
