car died
Old Nov 23, 2008 | 06:35 PM
Lilspleen's Avatar
Default car died
alright well i have a 1998 camaro and i had an auto start put in about a month or two ago. i was driving last night at 15-20 mph in 2nd gear and everything in my car died the cd player, headlights and etc. what could be the problem? thanks
Old Nov 24, 2008 | 02:31 AM
Posi's Avatar
Default RE: car died
Battery, possibly Alternator. Wouldn't hurt to have them checked. Mine died pulling into a parking spot last week, but it worked for that day and then wouldn't start the next morning so I jumped it and took it to Les Schwab and thankfully it was only the battery.
Old Nov 24, 2008 | 11:21 AM
RS96LSU's Avatar
gotta be the alternator. a couple months ago, i was driving home and my radio cut off and my lights started dimming. i had to roll into a parking lot. changed the alternator next day and its been going strong since then.
Old Nov 24, 2008 | 11:22 AM
TomS68's Avatar
Did it just suddenly flame out or were the lights getting more and more dim and then it cut out? Does the dome light come on? Check all your fuses, and check your battery connection by wiggling the wires to make sure you have a good connection. If your connections are covered with white crap then unbolt them and clean them. Water used sparingly with a towel and a wire brush to clean the contacts should do the trick. Reconnect the battery and check the dome light. Does it come on? If it does and it's bright, make sure everything else, stereo, fan, lights etc, are all off and try and fire it up. If however you connect the battery and the dome light is dim then the battery is drained. Try charging the battery if you have a charger or swap out the battery for new one. Again fire it up. Now check your alternator gauge on your dash. You may have one on the far left of your dash board. I'm not certain if that's a standard option. I have one that's all I know. Gently rev the engine. The alternator charge should alter slightly with increased RPMS. If it doesn't and if it just keeps rolling slowly down down down, then you've got a bad alternator and you need to swap that out. If you put in a new battery or charged battery and you still get a big fat nada with the dome light and all your fuses are good then things get more interesting. For now though I'm betting that your alternator died and you didn't notice it until your battery actually failed. When an alternator dies the car will use the juice in the battery alone. This drains pretty rapidly and usually lasts around maybe 15 minutes before it's had it. This is by the way extremely hard on the battery and can shorten the battery life. Hope this helps.
Thanks,
Tom
RonnieJ86
Jul 26, 2014 01:35 AM
1976camaro
70-81 V8 Tech
65
Sep 17, 2010 01:36 PM
Swiftpain
Aug 12, 2010 04:52 PM
95Camaroman
Nov 15, 2008 08:41 AM
jimidude87
82-92 V8 Tech
Apr 14, 2008 10:25 PM
