Internal Dash Panel
Old May 29, 2008 | 12:47 PM
roachdogg28's Avatar
Default Internal Dash Panel
My camaro is experiencing electrical problems including lack of speedometer(needle doesnt move at all) and what seems like a short in the windshield wipers. (they stall or just dont work)
This only recently started happening after i replaced the engine.
The dealership said it was a short in the internal dash panel, ive never heard of one of those, or is that just a fancy name for the gauge cluster?
Thanx for and help
Old May 29, 2008 | 12:50 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: Internal Dash Panel
there are alot of wires running behind the cluster, probably something grounding out in there IF that is the problem
Old May 29, 2008 | 12:54 PM
i took it apart and found power wires have power and all grounds are grounded properly. So is the "internal dash panel" a cluster? because i could replace it easily i have an extra.
Old May 29, 2008 | 01:05 PM
Ninja Administrator
it may be the cluster itself but i really cant think of any way for this to affect your wipers, unless your wiper motors are just going out, in which case you have 2 problems, not 1.
if the cluster just breaks that can cause a needle not to move.
you would want to get this tested to make sure its nota bad signal coming into the cluster as opposed to a bad cluster itself
Triangle12
May 21, 2013 08:30 PM
Techbox
Aug 5, 2012 09:00 PM
black68
Mar 29, 2010 10:16 PM
South Australian 68 SS 396
Jul 28, 2009 08:19 AM
1995Camaro
Mar 20, 2009 12:09 PM
