Ignition switch issue?
Old Jun 19, 2013 | 01:10 AM
jml2002's Avatar
Default Ignition switch issue?
How do you get to the ignition switch. Do you have to remove the steering wheel or can you just lower the column down.. sometimes I go to turn on the car and when I put the key in to turn it it turns without catching. And also when I turn it off if I don't turn the key right it doesn't turn off correctly. I can tell cause the dome lights don't come on and I gota turn key to on and back to off till I get it right. So I don't know if the switch is broken or loose and out of place and the rod isn't working right. I hope this makes sense. I'm just trying to find out how to get to the switch the easiest way. Please post your comments.
Old Jun 19, 2013 | 07:47 AM
what i have is for the 93-96. check the 99 manual here. should be same as yours
My Files
JohnnyCars
Jul 23, 2014 01:27 PM
jetrebel
Feb 1, 2010 01:30 AM
w0211644
Mar 14, 2007 01:12 AM
muscleman
Mar 6, 2007 11:11 PM
Scott
Apr 1, 2005 03:55 AM
